jeepcreepcj
Hi, I am in the process of replacing the f22a6 engine in my 93 accord with a f22b2 from a 94 accord. The trouble I have encountered is that the ports on the head are different. I can use the b2s exhaust manifold to solve that side, but the intake manifold is a different story. I need to have the wiring harness from my f22a6 93 motor, but there is no way that I can put the manifold from my car onto the new engine, even if I modified the ports to match, the coolant hole from the head to the manifold would not align. Also, from what I have read, the head from an a motor wont fit the b because the b head is wider and one of the water jackets overhangs the block. So, is there any way I can use the manifold from the 94 in the 93? Or is there any other way to make this work? Thanks!
