93ludew/f22b
I Have A 93 Lude With A Jdm Dohc F22b And I Cannot Get The Oil Filter To Stop Leaking I Am A Technician And I Change My Own Oil And It Has Never Happened To Me Can Ou All Help Me Out
reckedracing said:did you check to make sure there is only one o-ring on the filter?
sometimes the oil filter "gasket/oring" will get stuck to the block, then you put a new filter on with the new gasket, then 2 gaskets = leakage from hell...
check it out
Hey there, I currently have the same problem.
I had a small oil leak and was burning a little bit of oil on the exhaust probably about like yours.
I changed the oil and everything and it is still leaking. I've got your solution, trust me.
Now, go ahead and change your oil yourself. When taking off the oil filter check to make sure there is not and extra o-ring from a previous oil filter tht was on it. Im almost 99% positive that is wht mine and yours is doing and if not sorry.
Have a good one bud.
I don't think "GOOD INFO" has an expiration date..
Maybe that's why sites have an archive from years and years past.
"there will ALWAYS be NEW-B's" that's what keeps an industry going strong.
E
Took the words right out my mouth..
