head gasket:
mynumber1hater
B18c1 bottom end
GSR crank and rods
CTR .25 over pistons (PCT)
ARP head studs
ITR water pump
B16A oil pump
NEW tensioner
DC sports 4-1 header
head:
B16A head, ported and polished, 5 angle valve job
ITR cams
ITR valve springs and retainers
ITR injectors
B16 intake
THIS is my set up what head gasket do i need? part number too please.
It really depends on what you want to do. If you want to go NA and raise your compression a little then buddy club makes a thin head gasket. Otherwise just go with a OEM. Sorry dont have the part numbers on me.
Cometic head gasket. google them and call them up. they will tell you what you need.
Read around on the posts though, I have seen a lot of complaints on the Cometics leaking/ not lasting long at all, but that can always be inproper installation as well. Are you going NA or possible forced induction?
read around on the posts though, i have seen a lot of complaints on the cometics leaking/ not lasting long at all, but that can always be inproper installation as well. Are you going na or possible forced induction?
cometics are tried and true. Anything wont lastm long if not done right or abused......... I have a cometic head gastket and it has worked great for me.
