new swap question
93f22a1
ok guys so i am trying to decide what i should swap into my 93 lx. i can do a straight trade my f22a1 for a jdm f22b or i can get a jdm f20b from the accord sir. which one should i do? and im not wanting to do an h22 swap so dont give me that option.
F23 block (86.00 bore)
F23 crankshaft
F23 pistons
F23 rods
F22 head (milled 0.030)
3 layer OEM head gasket
H23 ARP studs
H23 intake manifold
B16 throttle body
H23 manual transmission
9.90:1 compression ratio W/ 2253.8 cc dis
0.000 piston-to-deck height
1.45:1 Rod / stroke ratio
0.040 shaved on head will yeild a 10.11:1 compression ratio
i dont want to mix and match a bunch of stuff
i can do a straight trade my f22a1 for a jdm f22b or i can get a jdm f20b from the accord sirquote]
The quote says it all
You dont wanna mix parts, hey buddy thats alot of the Honda building world. You ask our opinions on a engine swap thats covered over and over, do your homework. The F20B is a 2.0 liter with a H22 head, the F22b DOHC is basically a destroked H23, the F series make good torque numbers and are readily availible when it comes to parts. You asked you got....if you want vtec but not a H22 then you have a option of a F22b1, H23vtec, F20b, or a F23vtec.
