EP3Hatch1987
Meeeeooowww!!!!!
does anybody have pics/info on how you ran your drain line? cause im having some diffculties doing so... it would help thanx
You can always go with rubber hose. It's more flexible and won't kink on you. I'm running a piece on my setup right now because the braided line wasn't flexible enough for what I had going after I put my Moroso pan on.
What kind of manifold is this, and where is the drain setup to go into the pan?
I hope your engine dosent like oil pressure and runs better with no oil, because thats whats gonna happen when that rubber hose explodes.
I have seen two take a shit at the strip, talk about fucking everyones day.
Use braided lines, do what you may to get oil to the turbo but please use braided lines.
A mini log and it sits really close to the pan? Strange.
What turbocharger is on the car at the moment, and is it the turbo you will be using when the car is running?
Also, I'd suggest trying to re-clock the turbo. You might be able to change the angle of the drain in order to keep it from kinking on you.
