which hasport mounts for 1995 del sol with b16
jachrist
I want to replace the mounts on my del sol with black hasport ones, but don't really know which ones I need. I have a 95 del sol si with a JDM b16a swapped into it.
Thanks guys
Thanks guys
If your del sol has the jdm b16 swap with the factory style mounts, then you can use the Hasport EGSTK, but if by any chance the driver's side bracket has 3 bolts (integra style) then use Hasport DCSTK.
This will tell you how to tell the difference between the 2 bolt and 3 bolt mounts How To Identify 2 Bolt or 3 Bolt Post Mount Style on 92-00 Civic and 94-01 Integra
