can anyone please help me i need to know where the wires go from the drivers side shock tower into the engine wiring harness the car has a d16a6 in it and the drivers side plug is the small 8 wire plug thank you to anyone who can help
ok my injectors go straight to my ecu and the yellow black wire for the injector resistor is to the main relay if im worng where is the fast idle valve located
ok i just wanted to make sure as i have 3 wiring harness for the car 1 is an si that i had to remake 1 is a jdm si harness and the other is a dpfi thats why i was asking
