he can dyno right now and probably get 250...the gay bryan got 253 on an all stock turbo ls..
my shop says i have to get rid of my FMU {which was already in the car when i bought it} i dont even know what it is. that will free up more power. is this true????? by the way fully tuned at 5psi with hondata.
wow tuned on 5psi..up the boost and run the right stuff and you will def. get better numbers..
also the best head would be from the gsr b18c1,because it doesnt raise compression like the type-r or b16..
you are correct..my head isnt on straight lolI think you might have that a bit backwards bro:
The GSR head increases compression more than the b16.
Also, the b16 gets better numbers on flow bench than the gsr head (stock v. stock), which makes it better for turbo apps. The design of the combustion chamber in the GSR head make it a better candidate for an NA motor.
