z6honda2009
alright im woundering what other heads i can put on the z6 can anyone help me out please.
what's that?becase i had to wire my car to si to even use the engine in my car 91 hatch
let me break it down even more to try and understand,, so you perty much converted your car to 88-91 si 4 injectors correct ? and its running like that now correct ?ok i dont think im explaining it that heres what i did i took a d15b2 out of my car witch is only 2 injector and put the d16z6 in witch is a 4 injectors so when i did that i had to wire the car to si to have the 4 injectors k i used a 89 dizzy and a si ecu witch is not vtecso pretty much i cut and moved wires and add wires for the dizzy and so forth so i cant get a jumper for the p28
