need help please!!!!!!!
Egturbohatch
sup honda freaks...including myself.............i have a b18b1 in my 93 civic hatch on boost and now its blowing blue smoke.............i believe its da rings so since it snowing soon around my area im planning on taking da car off da road and rebuild it so my problem is it's my first time taking da motor out but ive seen my boy did it before and i did alot of research and pretty sure im good but i'll be doin it myself wit no help wat so ever ( is dat a good idea) do i need help doin dis job or not............please any suggestion on motor rebuild please let me kno it's goin to be a 6 months project cuz da car is not coming bakk out till spring.....so please give me any advise i would appreciate it..............is it ok to drive wit da blue smoke????.....blue smoke only comes out during acceleration and wen i put it in neutral it blow white smoke not too bad but its enough where u kno something aint rite..............let me kno
A couple of things...
1. Your grammar sucks. I got a headache trying to read that garbled mess. Ask legible questions and you will get more responses.
2. Before you rip into the motor, you need to diagnose what is wrong with the car. A simple compression and leak down test will go a long way towards this. You don't want to rip the motor apart, spend a thou rebuilding it, put it back together, and have it still smoke because of bad valve seals? Are you loosing oil? Coolant? Is coolant mixing with the oil?
3. Give us these answers and we can point you in the right direction.
i kno my grammar suks. sorry.. but no havent notice any oil leaking or losing any. coolant looks ok
btw how long does it takes to do these test? does $100 sounds reasonalble for a shop to pin point wats causing the blue smoke by doing a leak down/ compression test and scope thingy watever he said. but let me kno
If you have a Harbor Freight tools near by you can pick up everything you need for around $50 (random guess). It's easy to do, and you won't get suckered into a shop ripping you off.
can u make a list for wat i need please, plus instruction like a step by step on doing it would be nice.---------so hows my grammar now....lol.....theres a Harbor Freight tools like 30-45 mins away in worcester, ma so let me kno the list, thanks
