Taco15
I wear stretchy pants
here's my write up folks!
ok finally started doing some work. After the pioneer unit came in figured i need to get cracking at the dash kit. My friends at the shop are just letting me figure it out on my own so this is what i'm coming up with.
this is what the trim normally looks like
after taking another one of of a Blazer i started cutting. I took the same plastic used to make dash kits and made a back piece and the trim that the din will slide into.
i then filled the sides with glass bondo and started sanding.
as you can see i started shaping it to somewhat look factory. i think its better than the squared one i saw online.
