Anyways, i was thinking that since most of them are rwd anyways, why not drop the s2000 engine in one.
Someone is doing this already, but they have the sense to use a s14 rear end. Hell the S2k rear would be a better choice. Or a shortened Ford 9", or pretty much every small rear drive setup other than the wagovan rear end which was designed to handle a fraction of the output from a D16.I would like to chop up a shitty CRX to put in a F20C with the Civic WagoVan rear end.
I've never seen that CRX build. When I first clicked through I thought, "Oh no, why would you do that to such a clean CRX?". Then as I read and looked at the pictures, it's obvious that guy knows exactly what he is doing.Someone is doing this already, but they have the sense to use a s14 rear end. Hell the S2k rear would be a better choice. Or a shortened Ford 9", or pretty much every small rear drive setup other than the wagovan rear end which was designed to handle a fraction of the output from a D16.
my rwd crx project CRX2000!
