1, it's vtec not vtech, it's not the electronic company. and 2 why would you want to swap over the valve cover? did you do a mini me swap?
I'm not sure if you read what I put in my post but it doesn't say vtech, it says vtec! And I was just curious, I want a "wrinkle" red valve cover for my y7 but vtec valve covers are easier to find than non in this style. Thanks for the info guys
awesome this is what i was looking for! one more question do i need to prime the valve cover before painting?Step 1 - Buy this: Klean Strip Aircraft Remover Paint Stripper Spray Can:eBay Motors (item 200311516591 end time Nov-14-09 15:50:59 PST)
Step 2 - Use it on your valve cover
Step 3 - Buy this: Amazon.com: VHT SP204 Wrinkle Plus Coating Red Can - 11 oz.: Automotive
Step 4 - Use it on your valve cover
Step 5 - Enjoy your wrinkle red Y7 valve cover
d16y7what engine?
D16Y7 non-VTEC spark plugs are in the front just like a D16Y8 VTECno a vtec valve cover wont fit on a nonvtec head..vtec spark plugs are in the front upper part of the head.where non vtec are in the rear upper..
so are you saying a y8 cover will fit a y7 head in this case?D16Y7 non-VTEC spark plugs are in the front just like a D16Y8 VTEC
yes, they are the same - the Y8 doesn't say VTEC, if you were looking for thatso are you saying a y8 cover will fit a y7 head in this case?
that looks great did you tape off the letters or just scrape them?I didn't prime coat mine just prepped it good.
