RadekSkylark
Ok, I got EG 4door, for DD, and it will stay as DD
so, I can get z6 head, rebuilded for ~350$, then was thinking of some 4-2-1 header, got an 60mm exhaust, then get in tuned
in Compression Calculator by ZealAutowerks i did this setup with d15b2 stock block + unmiled stock z6 head, 2layer HG, and got CR 10.54:1, so whit this setup runing on 93 gas, and a good tune, what could be the nummbers on wheels - hp/tq??? And if I will do this, the next step will be z6 block 75.5mm PG6 pistons, lightened flywheel, and oem z6 HG. it will get me to CR 11.8:1 on the same 93 gas. Or, I will do something with head internals, the best i was thinking of is bisimoto stage 3 camshaft + AEM cam gear, valve springs & retainers... and so on.... BUT, the question is, whit the start Mini-Me setup CR 10.5:1, 93gas, rebuilded z6 head, 4-2-1 and 60mm exhaust + good tune, what could be nummbers to wheels??? ok guys, thanks alot
