trans in my g/f ek is toast picked up a trans at japan power in ottawa off a d15 is what they told me. will it fit with out any probs? it has numbers on it would that help identify what i got better? was 300$ and needed one bad. firts 3 gears in hers sound like there going to explode!! even sounds bad at idle like it chewing it up inside idling unless you push in the clutch and stop it from turning inside.
anyway I read that it should work on several threads and I'm attempting to replace it today. even if it works i wouldn't mind knowing what the gearing is in it and so forth.
numbers on trans S20-1568641
