rex
rex41
I have a dx crx. N I want to know witch engine wud be good to boost . I wana hit 300 or 350 hp? Any idea? Thanx 4 the suport .....
never build a car/engine to beat one car or one kind of car because there will ALWAYS be one thats faster then you
oh yeah without a doubt a b-series either all motor or boosted would blow away a lot of cars just because or the tune and power to weight ratio. it also depends on how you build it, because if you just slap a turbo on it and call it a day you would pop the engine like it's your job, but if you actualy take the time to build it and tune it, it'll be one bad car
<br />
<br />
Oh. Okay. Well I have a b18b. N im tryin to boosted it. So I was just wonderin if it wud handle good wit turbo......
Wtf is with the "<br />"?
Anyway you need low compression pistons. That motor is in the 11:1 compression ratio range when you want it in the 8.5:1 range, maybe higher but not much.
What you need to really do is a shit load of researching and reading. Search Google for turbo, building a motor for turbo and tuneing, tuneing, tuneing...the most important part of a turbo build.
lmao wow...you can turbo the stock LS and make around 250hp safely..or you can upgrade rods,bearings,and rod bolts and run higher numbers
Wtf is with the &quot;&lt;br /&gt;&quot;?<br />
<br />
Anyway you need low compression pistons. That motor is in the 11:1 compression ratio range when you want it in the 8.5:1 range, maybe higher but not much.<br />
<br />
<br />
<br />
Idk?? But thanx anyways.. Ill see if get this done by the end of this year.
hahaha.. what??!?
a b18b is in the 9.2:1 range.. lol..
b16s dont even have that high of compression ratio..
Ahh shit, I was thinking of the JDM B18C version. I assumed it was JDM because he didn't say "B1".
You're right Cal, OBD1 conversion and a chipped P28 ECU or Hondata ECU.
Fuck it, I'll stick to reading and not posting.
