which housings do HIDs more Justice Halo vs. JDM
justice = allows to shine brightest and gives most visibility to driver....b/t clear Halo projection (Angel eyes) and JDM clear housings???
Opinions opinions opinions:eek:..................................:ph34r:
Neither because you're not going to toss in a cheap kit that throws the wrong beam pattern. Do a proper HID retrofit and don't blind your fellow motorists. You'll have the best visibility this way too.
At the OP's request, I'm going to reopen this thread in a more appropriate forum...
I'm working on tryng a DIY to get that HID light more centralized.
and because everything in my car is going black.....
what CAL said is correct if you want to do it the most efficient way
Retrofits are kind of a PITA, but its the only way you're ever going to get a proper lighting system with HID's. There's a reason why cars with HID's from the factory also have projectors. It keeps the light beam centralized and out of everyone else's eyes.
what about on Integras.. they have a projector style beam... would a kit work on them
i was looking into them since ti saw this thread. What i want is to get a newer front end. The newer rsx headlights are not only housed in black but have 3 lights that are similar to projector type...unless they are factory hid's (USDM)
I know the JDM ones are but holy crap they are expensive
i think my 02' style headlights will look too ricey if i paint around it black except for the 2 huge hole for the lights. Its the only thing i can do now to save money. 05+ front ends are sexy as hell
Better than just putting a kit into a reflector housing, but no.
*NOOB QUESTION* but i really dont nkow...is the projector on the left side? If so the Halo projection casings have that too! Which was what I wanted to go with. My friend just has the clear JDM housing and his lights are pretty bright, a little too bright for 8ks if you ask me, my thing was that I haven't seen Halo projections in a while but from memory remember them not being that bright and wanted to know what was up with that.
CAL send a link of what yo'ure talking about please because I am COMPLETELY lost
I did a set of black housings on a set of OEM 02 RSX-S headlights, looked awesome.
hmmmm. I'll try to pull up a pic.....
