Yep, that was a super easy fix, I looked at the old automatic shifter and figured out which wires you need. Basically on the side of the old automatic shifter there is a white slide switch that is bolted on, take it off. Take off the zip-tie and remove the tape around the wires. There are three black wires in there, 2 striped, 1 not. Cut black wire (not striped) as close to the solder joint as possible. Cut the green/white wire (farthest green wire away from harness) as close to the solder joint as possible. Splice, and SOLDER the two wires you just cut together, shrink tube or tape it. Plug the nine pin wire harness in and leave it under the molding, nobody is going to look under there anyway. Your done, you can now remove your key!
