EG wire tuck...
EP3Hatch1987
Meeeeooowww!!!!!
my new build.. im getting new turbo manifold.. bisi spec (hurricane hedi turbo.. lol) and doing a full wire tuck.. also might be getting harness from rywire.
tucked injector harness.. easiet 1..
pictureof before with battery and fuse box removed already..
body harness removed waiting 4 new 1..
waiting for turbo 2 come in from bisimoto..
car tookin apart and fresh paint by ME.. was red sprayed black
juss waiting 4 parts now...
FInished running the head light harness on driverside got everything where i want it...
also removed the dash 4 a lil easies access and 2 do the full tuck 4 everything 2 meet in the middle of the dash 2 be hidden..
pulled the engine harness out had 2 do some mods..
took off all the heat resistant stuff..
the partical finished product.. need some heat resistant nylon.. un tangled them and wrapped individually..
pulled the heater core out.. so i can stick the wire threw the hole..
didnt get into much detail after this juss wanted 2 finish my project so heres the final result hope you guys like it....
AND USED ALL THE STOCK HARNESSES.... also a thanx 2 my boy phil 4 helping me with the tuck...
how do u like that dampener of the dr side of the motor thats the first one of those ive seen and my 89 hatch could really use something like that
It works well.. But if I had solid motor mounts that would help a lot more.. But overall it works good..
The 3m stuff works great if the mount is not already broken. If it is broken then it dose not hold up in my experience.
