clutch slipping
keith605
if my clutch is slipping could i just get my flywheel refinished or would i just have to get a whole new clutch / or new flywheel i have a stage 2 in there right now
Stage 2 doesn't mean anything...
If your clutch is slipping, you likely need to get a new disc at a minimum, maybe a new pressure plate. Refinishing the flywheel is always a good idea.
allright thanks
:werd:
you need to look at the torque capacity of the clutch and not let phrases like "stage x" sway your decision. There are a few companies that make a stage 2 clutch that handles 300ft/lbs of torque and some that make stage 2 clutches that handle 180ft/lbs.
