oil pan
turboef87
can u drive with a tapped oil pan just the drain line on it but no turbo i just wannna put this pan on already just want to kno if oil gonnna come out of the line illl have it up just like if it was on the turbo kinda stupid question but i dnt give a fuck lol
Why do something twice?
Put the pan on witha new gasket, cut a piece of the same diameter heater hose as your tube about 2 1/2 inches long, plug one end with a bolt/metal plug/whatever, then hose clamp each side. Done.
It wont leak if you do it right. Then you wont have to waste the money on another oil pan gasket and you reduce the chance of pulling threads from your oil pump or block since you are only torquing stuff once.
Do what ya want though.
