h22 rebuilt
tat
hi guys new to this im doing a conversion to my eg with a h22a2 engine i want to now what parts would be the best to use as im planning of putting a turbo on it like pistons,con rods,head gasket,cams and ecu thanks
I believe your best choice in pistons is going to be mahle gold series, and eagle rods probably. re-bearing it and call it good
h22 rebulid
ok cheers what about turbo kits what the best turbo kits and what cams should i go for
I would recommend peakboost if you are looking for a complete turbo setup.
save the money for the cams, just leave them stock for now
if anything get a good intake mani, and have some headwork done. that should suit you well. honestly though id just save your cash for a nice turbo setup. it's well worth the extra dough
FIRST...
You get the block Sleeved...Do not boost that thing without Sleeving it, FRM Cylinders do NOT handle boost well regardless of the piston choice u run. AFTER you've sleeved the Block..
Mahle Gold Series Pro' Low Compression Pistons
Eagle Rods
Valve Train (For Turbo Applications)
Boost Controller
Turbo Kit
Intercooler
Injectors (I'm using RDX Injectors with a Custom Fuel Rail)
Hondata S300 (And a good tune)
H22's are notorious for HIGH horsepower numbers and even more staggering Torque numbers on boost...live free and drive well.
theblur is right on the money. sleeve that block for sure. for your turbo kit I would recomend that you stay away from peakboost and spend the money on fullrace.
