Phil_Civic
Hey guys,
I'm in the middle of changing my water pump/timing belt on my 93 Civic. But I can't get the crank pulley bolt off.
I have air and an ingersoll rand impact gun that's supposed to make 780 ft lbs that isn't touching it. I've taken the starter off and tried jamming a big screwdriver or a pry bar in the flywheel and using my 24" breaker bar with no success.
I'm not crazy about the idea of heating that bolt up either...I've heard of guys lodging the breaker bar in there and cranking the engine to get it loose, but I think the engine turns the wrong way for that, and I'm not a fan of that method anyhow. My head is off at the moment so I couldn't try it if it did come to that.
My only thought now is dropping the trans and taking the flywheel off and using the flywheel bolts with a screwdriver to hold it steady...
Any ideas how to get that thing off?
Thanks a lot,
Phil
Thanks a lot,
Phil
