youll also need some custom motor mounts if your wanting to go over to b-series.
And FYI, don't even attempt this swap. It's retarded. The B16 only puts about 20 more horsepower then the engine that's already in your car, and only at super high RPMs anyway. Combine that with the fact that the B16 puts out significantly LESS torque then your current engine, and you'd probably end up actually being SLOWER.
Nobody makes mounts to put a B-series into 1990+ Accords, and this is the reason why...
ok same car what about an f22 vtec swap out of an 94-96 accord what would be needed
