B18C (JDM 1993 GSR) going into a 91 CRX si
tastypotato
Okay, so a friend of mine is literally going to be giving me everything in his 1999 Integra LS's engine bay which includes a 1993 GSR motor with the transmission and everything else. Problem is, he never got the proper GSR ECU so I know I'm going to have to get that.
I'm kind of trying to put together a parts list and I was hoping that you guys would be able to help me put together a to-do list.
Parts that I have:
93 GSR w/ hydro tranny complete with clutch and flywheel.
99 Integra Axles (going to work?)
Alternator
Starter
Intake Manifold
Exhaust Manifold
Fuel Rail
Injectors
Dizzy
Motor mounts (For a 99 Integra b series)
Parts that I'm going to need:
A book about motor swaps
A lot of patience
Rywire jumpers
P72 ECU
So, what am I missing from my need list? Thanks a bunch in advance guys, I'm a total newbie at this. :(
Also sorry for the double post, but here's my baby as she sits right now with her D16A6.
Just thought you might want to have a CRX to put to the username. :)
Well ur gonna need to get custom motor mounts for the bseries swap for ir crx ur also gonna need custom shiftlinkage from hasport or if you have access to a welder you stock bseries linkage cut it and re weld it I did it that way saved me about 200 lol I'm guessing ur car is already mpfi and not dpfi if it's dpfi ur gonning to need to do that your gonna need to wire in the vtec and ur also gonna need to do a cable to hydro conversion to use ur gsr tranny I don't recomend it, I've heard bad things but that's completely up to you if you wanna spend the extra cash if not I'd recomend b16 cable tranny or b18
that is a sexy rex ^^ +rep
Why thank you. :D My Canon Rebel XSi can make my car look quite sexy even though it hasn't been washed in 1 1/2 months. :p
Anyways, since I can't edit my original list I shall just continue it here with what I'm going to need.
I've been talking with other people and I believe that I've been able to find all that I'm going to need to get before I start to put this sucker in:
This is what I'm going to need:
Rywire - Online Store
Wiring subharness
http://www.innovativemounts.com/ProductDetails.asp?ProductCode=41000
Hydro -> Cable
http://www.innovativemounts.com/ProductDetails.asp?ProductCode=B49150
B Series motor mounts
Still need to figure out what kind of ECU I'm going to need to get to make this CA smog legal, Either a P61 or a P72 ECU, don't know which to use right now going to go and google some more. I also need to find a place for B series Axles that are NOT Hasport because they're super expensive. :/
Finished pulling the B18C out. My friend also gave me a P72 OBD2 Ecu which has a crank sensor on it which will complain if I try and hook it up with this motor..
Now to just start collecting parts to get the motor into MY car.
