whats up every1, i'm new to swapping....so i need a lil help.
I have 97 accord LX and was thinking about putting a h22. I heard the h22 is the best
and simplest swap.....is it true???? thanks
Make sure you get an OBDII and not OBDI motor. It is all about compatibility between the engine, ECU, and wiring harness. You will save many headaches and lots of work/money by doing this. If you grab a 97+ Prelude engine You will be golden.
