94 acura parts!!!!!!!!!!
BoostedHatch
get tha fuck out!
i bought a running 94 acura pulled the motor and put it in my car but i pulled some interior peices and body peices.
tail lights $30
rear hatch (pick up only) $20
rear bumper (pick up only) $10
rear bumper filler (small unnoticeable dent) $15
b series a/c condensor $20
b series power steering pump (fluid can is busted) $20
b series auto starter $20
brand new shift linkage for 94 & up teg 96 to 2000 civic b series $40
b series front tranny mount has small tear $5
d series stuff
d series intake manifold with tps and map sensors $30
d series manual starter $20
like new sparks plug wires for d series $10
i will check tomorrow if i have more and pics will be up tomorrow.
buddy needs engine harness and under dash harness PM me if you have them.
must be obd1 can be from LS GS RS or GSR
i still have the engine harness i dont have the under dash harness but the engine harness dizzy plugs are cut off i still have the they just need to be soulterd back on and when the motor was pulled the knock sensor wire got pulled out of the plug so it will need one ill sell engine harness obd-1 for 50$ lmk
You don't have the headlights do you? I'm having the hardest time locating a stock set.
