1993 honda accord lx coupe
joniboi
okay i have a 1993 honda accord lx coupe original motor stock non vtec factory motor all it has is an aem short ram air intake and i want more power out of it but i dont want to do a full engine swap yet and i been hearing u can put an h22 head on it and u can get more power ou of it what would u recomend i do with a 200 dollar budget
There isn't much you can do with a $200 dollar budget.
30 second google search got me this on the h22 head swap
G22 Swap:
f22b2 block
h22a head. machined/resurfaced
h22 obd1 intake manifold
p13 ecu or p28 chipped
f23 head gasket
f22 water pump
h22 water pump
h22 timing belt
h22 alternator
f22 water pipe from f22a
h23 crank pulley
h22 headers
h22a dizzy
f22 motor mounts of course
as for tranny I'm using my jdm h22 tranny with light weight flywheel & exedy stage 1 clutch exedy throwout bearing
h22 axles bc of my tranny
you have to plug 2 oil holes on the head.
you have to use f22 water pump with h22 water pump gear
With $200 as your budget you can give your car a tune-up, and that's about it. I'd budget at LEAST $500 for that head swap...
i say get some headers. It worked for me until i did my swap
That's a pretty decent idea. Megan Racing makes decent quality headers for fairly cheap. I think you'd have to drop a bit more then $200, but not a whole lot more...
