whats better pr4 integra ecu or stock 91 si ecu?
jasonga30224
i need to know which ecu will be better for a d16a6 pr4 integra ecu or the stock 91 si ecu
If you're talking about a fairly stockish engine, then the ECU that goes with the motor is the best choice. If you're tuning or switching OBD or something like that, then you might use a different one, but if you just need to run a fairly stock engine correctly, then use the ECU that came with it from the factory...
90-91 teg injectors are the same, but 92-93 i believe would be saturated and don't need/use a resistor box..
ok so the wire colors are the same?and is the resistor box on teg and civic si the same.
