H22 swap AXLE HELP
molotovman
I swapped my 94 Accord coupe with a 92 JDM H22a. So far i drove the car for 5 miles and the driver axle broke loose. What intermediate shaft & axle am i supposed to use. I tried the Prelude axle but the connection is different, and the Accord axle seems to be a little too small, and will possibly break again. here are some pics of my car
I recommend using both intermediate shaft and axle shaft from the H22. It's alot stronger than the stock accord axles. It will bolt right on the block and the hub.
if i use the prelude intermediate and axle will it have a longer reach?
the 94 Accord axle measures 24 3/8" which is too short
the 98 Accord axle measures 25 5/8" which was too long
the 98 Accord Pass axle measures 24 15/16" I will try it just need to change the inner part.
that helps me out but my other ? is i have a 94 accord dx four dour and im planning on dropping a h22a in there as well but i need to know will the the tranny mount up to it or not?
