ihi turbo
turboef87
i got a good deal on a subaru legacy ihi turbo i wanna boost my b16 with it 12psi any 1 think i will be pushin the turbo to much with the high rpms of the b16 thiz iz my daily driver so i dnt beat on it just open it up every now an then feeel meee lol
if you are not on it at every light then should be fine.........doesnt matter imo how many differant ones they made
...right because size of the turbo means nothing. GT42..GT25 same thing. :bangdesk:
either one will be fine for what he is trying use it for.......thats what i am saying.......
Ok...based on this information you're telling me im getting the impression you have no idea what a turbo is because you would know; size matters. Christ.
Listen noob.............. Dont be a douche......
yo 2 b real i been tryna find out excactly what turbo this iz but i cant find it thiz iz pics of it i kno it haz a subaru hotside but idk heres some pics
ok what does the name plate say? and it has an external wastegate......... not sure but probly 6-8psi oin that external waste gate. but i am not for sure on that.
That is way small for a B16. Im running a T25 on my d series and hit full boost (8 psi) at 3300-3600. That will thing will make a little over 210-225 HP on a b16, maybe.
the turbo spec says VF48610 serial numba RHB5 01065A parts numba 14412aa031 do u kno were i can get that inlet flange on the compressor for thiz i tried lookin around and cant find it i need a new gasket 2 as u can see
i think that turbo iz better than a t25 i got other lil shit done 2 the motor 2 help out gsr cams port match p30 intake manifold to itr throttle body full msd kit i just wanna make 250 just a fun daily driver im not trynna take the streets ova with it lol
I have personally seen both of those turbos, disassembled. That would be the worst turbo to run on your car.
1) The Subaru flange on it: good luck finding a manifold for it, unless you are going to make it yourself
2) Its way too small. Yes, you can run it...but why would you? Its horribly inefficient and will be extremely too small for the application.
its an INTERNAL wastegate.
right, depending upon the tuning and other parts as you have stated.
this.
its or it's.
the.
know.
to.
come on, its really not that hard. it makes your posts annoying as hell to read.
youd be better of with a decent t3/t4 (garret or likewise, an A/R58 60 trim t3t4 would spool very quickly) but suit yourself. youre going to have a hell of a time getting that turbo to make 250 IMO. its just too small for what youre looking to do. and if you do push it there, it probably wont last long. that and you will have to worry about cylinder pressures because you will probably have to go upwards of 18-20psi to get that thing to make any power. on your 10.3:1 static compression ratio b16(already fairly high) that wont be a good combination.
like people always say: get the right tool for the job. this isnt the right turbo for your power goal.
yea fuck it i got a good deal on it illl just flip it and buy a new 1
this.
its or it's.
the.
know.
to.
I already know im going to like you. Can we be E-buddies?
