if you are not on it at every light then should be fine.........doesnt matter imo how many differant ones they madei got a good deal on a subaru legacy ihi turbo i wanna boost my b16 with it 12psi any 1 think i will be pushin the turbo to much with the high rpms of the b16 thiz iz my daily driver so i dnt beat on it just open it up every now an then feeel meee lol
its an INTERNAL wastegate.ok what does the name plate say? and it has an external wastegate......... not sure but probly 6-8psi oin that external waste gate. but i am not for sure on that.
right, depending upon the tuning and other parts as you have stated.That is way small for a B16. Im running a T25 on my d series and hit full boost (8 psi) at 3300-3600. That will thing will make a little over 210-225 HP on a b16, maybe.
this.the turbo spec says VF48610 serial numba RHB5 01065A parts numba 14412aa031 do u kno were i can get that inlet flange on the compressor for thiz i tried lookin around and cant find it i need a new gasket 2 as u can see
i think that turbo iz better than a t25 i got other lil shit done 2 the motor 2 help out gsr cams port match p30 intake manifold to itr throttle body full msd kit i just wanna make 250 just a fun daily driver im not trynna take the streets ova with it lol
this.
its or it's.
the.
know.
to.
come on, its really not that hard. it makes your posts annoying as hell to read.
youd be better of with a decent t3/t4 (garret or likewise, an A/R58 60 trim t3t4 would spool very quickly) but suit yourself. youre going to have a hell of a time getting that turbo to make 250 IMO. its just too small for what youre looking to do. and if you do push it there, it probably wont last long. that and you will have to worry about cylinder pressures because you will probably have to go upwards of 18-20psi to get that thing to make any power. on your 10.3:1 static compression ratio b16(already fairly high) that wont be a good combination.
like people always say: get the right tool for the job. this isnt the right turbo for your power goal.
I already know im going to like you. Can we be E-buddies?
