INJEN78
HS LEGEND
anyone have a fitv and/or an iacv that will fit a d16z6?
idle air control valve
fast idle thermo valve
must be in working order..
also the iacv is the thinner bolt pattern..i do not need the wider bolt pattern..if your unsure check with another on that isnt the same size.
and the fitv is the one that mouynts with 3 bolts...does not have an electrical connection on it
