loleven with all the fucked up places i go and all the shit i download i have managed to stay clean
AVG Free
MBAM
Spybot S&D w/ TeaTimer
AVG Free
MBAM
and a few randomly named MBAM executable files for those times that the malware in question is blocking MBAM from running its usual .exeRkill – Repair Tool of the Week
The malware world is changing. It’s getting smarter.
In fact, some infections will detect that you have launched an anti-malware tool such as MalwareBytes and close it down as soon as you open it, which makes your job much harder. This is the exact situation Rkill is designed for.
Rkill is a small, freeware and portable tool designed to terminate active malware processes allowing you to use other removal tools. Rkill is made by a Microsoft MVP “Lawrence Abrams” and is available in 4 different extensions. An .EXE, .COM, .SCR and a .PIF file.
The reason why Rkill comes in 4 different versions is because some malware will block .EXE files in an attempt to prevent you from running other malware removal tools, so this gets around that problem.
I tested this tool on a virtual machine which I had infected with a fake antivirus and Rkill killed the malicious processes without any problems. Of course, I then had to delete the malicious files manually as this is not a malware removal tool, but a malware process killing tool. It just stops the malware from running right now, allowing you work your computer technician magic.
