Built clean 94 hatchback
94 civic
1994 honda civic cx. with a b18b1
.New oem crank
.acl bearings
.arp main and head studs
.Golden eagle block guard
.Golden eagle crank girdle
.Moroso steel oil pan
.Eagle h beam rods
.Cp 9:1 Compression pistons
.Cometic head gasket
.Brand new oem oil pump, water pump, and gaskets
.crome pro chipped po6 ecu
. New bosal cat back exhaust
.The transmission is a 2001 gsr tranny with carbon coated syncros, and an MFactory LSD.
It also has brand new b-series shift linkage.
For suspension it has
. Eibach pro kit
. Ex front lower control arms
.EG6 front brake swap (from hmotorsonline
.Russel stainless steel brake lines
. Front and rear upper tie bars
The car also has an oem style vis carbonfiber hood, and duck billed spoiler, as well as GSR front leather seats, as well as a new alarm system, and has been completely rustproofed by Ziebart.
This car is built for turbo just needs a turbo kit, injectors, and a tune.
There is currently 10, 756 miles on the engine and a little over 6k miles on the tranny. Feel free to contact me at 585-690-9297
