affordable b16a engine mounts?
TommyHonda
can anybody recommend some quality,yet affordable,engine mounts for my 92 hatch with a b16a?
Don't get cheap crap like I did get the good stuff trust me you will be kicking your self in the ass if you don't, get hasport or innovative
Hasport's stuff is the best, but they might be a little out of your budget. Check out innovative. Their quality is pretty decent and you can opt for regular steel mounts instead of billet in order to save some money...
www.innovativemounts.com
OP" Do you mean you dont have any mounts or want a stiffer set of mounts?
If you need mounts....a cheap alternative would be to use D series mounts (for your car....92-95) but then just purchase the integra reat trans t-bracket. Go junkyard hunting....its not that bad.
Also, you can then search for articles on using window weld and other various products to fill in OEM mounts and gain rigidity without shaking your whole car.
I used no name previously and they only lasted a year. i was thinking of using innovative but wasnt sure how they hold up. thanks for the advice.
