dieing issues
chadcharb
Well-Known Member
VIP
so the gf's ef sedan is having a problems were the car just dies when she is driving. the battery was bad so i got a new battery and the problem persists. so i thought it was the altenator and put a volt meter on it and its putting out over 12v still. its a stock d15 with dpfi.
What is over 12v? Alternator should push 13.8v if all is well. If it's under 13v I would take it to the parts store for a load test.
Many times, when a battery goes south it takes the alternator with it - sometimes the alternator is the cause of the battery taking a dump by not charging it correctly.
it was 14v. I'm gonna pull it and have it tested tomorrow
ok - if it's cranking our 14v it's fine.
I would start looking at the distributor - sounds like mine when the sensor that times ignition went kaput. Sometimes it only had issue (miss) in one cylinder. Then other times it would randomly die. Sit for a few minutes, then start back up.
Good luck with it.
i went back to look at it today and now it wont fire at all. its throwing a code 16 gonna look that up
16- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-95 88-95 n/a 88-91 93-95 95 88-95
Fuel Injector System
defective circuit or unplugged / defective fuel injector
Wiring check - ground and connectors. Also, those diagnostic self tests don't always nail it 100%. Strobe signal could be missing for injectors.
Look for sensor - in mine it's in the dizzy - your model may have a separate sensor on the cam or crankshaft for the injector strobe signal.
You're getting closer.
