87 crx si 0bd0 d15a3 swap to obd2 jdm d15b vtec help???
d15bhondacrx
im having trouble help me out..i bought an 87 crx si 5 speed had a d15a3 in it i bought an obd2 jdm d15b vtec what do i need to do to swap it i know i need ecu and wiring harness but i need help like can i use an obd1 harness and do i need a conversion harness and what do i do about the driver side motor mount
you need to fabricate all new engine and transmission mounts - the JDM D15B won't bolt to the 87 transmission (different bolt patterns) - you will need to use the 88-91 CRX/Civic L3 transmission, use custom axles and custom shift linkage - you will need to use the 87 engine wiring harness and make a bunch of changes to it in order to run the electronic advance ignition and VTEC - you will need a OBD0 to OBD1 ECU jumper and OBD1 ECU, like P28
b18 swap in my 86 crx si
I want to swap a b18 in my crx, first of all will it fit? does anyone know where i can get the custom axles and the mount kit if it does fit
hasport makes mounts for d and b series swaps for the ew's now the price is 399:cool:
