need help choosing engine
masterkush
So im getting kinda ahead of myself because i have yet to even obtain my integra, but ill be getting a 3rd gen shortly, i dont know which model but not a gsr or type r and i have a 10k budget including the car and i want to get the best engine possible. Ive done some research on b18c k20a/k20a2 and the k24a but i cant come to a conclusion. Any information/stats/opinions would be greatly appreciated.
for a total budget of $10k including the car you are not getting a K swap
im only spending 2-3k on the car, how is 7k not enough ive read alot of people piecing it together for under 5k
you can piece a k swap to gether for that price. but in order to do that the k24 out of a accord does not have the power to really justify it. Where as with 7k you could easly do a type r swap with a mild build and have made more power for dollar compared to a budget k swap.
why not keep the ls that's in it now and just dump the 7k into it? rebuild it with low compression for boost and piece together a good turbo kit or rebuild it for high compression. And you could pick up a b16 head for it for pretty cheap ~$500 depending on what they go for near you because that's what they are about here
you can make more power on less boost if you dont lower the compression.
:werd:
Have you even looked into your options with the stock engine yet? A boosted LS will walk all over any stockish VTEC B-series swap, so definitely consider it...
