i have an lsvtec full swap..(valve cover will be either be pollished or painted gunmetal)everything needed to put into and eg.. ls cable tranny,chipped ecu,motor mounts,wiring harness,only have 1 axle..clutch masters clutch..(kinda rusty from sitting out) prolly can be resurfaced. also have a 57 trim garrett turbo, no shaft play..motor has about 3000 miles on it and runs like a beast..car was wrecked and motor and tranny were pulled. also have a set of integra special edition rims(sunflowers)2 brand new tires 2 have little tread.(195-55-15)
16" konigs 2 decent tires 1 iffy and the other is pretty bald. but all hold air..
-$2000 for the full swap....motor,tranny,axle,ecu,harness,clutch, turbo
-turbo alone make me an offer
-sunflowers-$200
-konigs $300
-also have a rockford amp 300.1-$100
-sunflowers-$200
-konigs $300
