Thanks!Welcome to Hondaswap! This is a very common question that we get quite often. I would start by reading up in here: Technical Articles and Reference - HondaSwap Forums. Anything referring to the "EG (92-95)" and "EK (96-00)" chassis will usually pertain to you.
An engine swap will cost you anywhere from $500 - 10,000 depending on what you goals are and whether or not you do the work yourself. First identify what you want out of the car and go from there.
you do a civic type r for under 4g's
