crx si question
ilovemyrex
i have a 88 crx si that i just purchased and wanted to put a d16z6 i dont have the engine wire harness and was wondering do i need the dpfi to mpfi conversion or is the 88 crx si model already mpfi ????:confused:
88 CRX Si is already MPFI. You need to add VTEC to the system somehow, or convert to OBD1 and use all the electronics for the D16Z6.
Welcome to Hondaswap!
yea i think ima go with the obd1 conversion.... know any websites that i can get the obd1 conversion and the z6 electonics???
Thanks!!
i have a d18y8
hey wats upp guy ok i have a d16y8 full swap harness,ecu,tranny,head,block. the motor runs but one of the rod berings went it has 125k on the motor and it has a brand new clutch on it only drove it around the block with the new clutch on im looking fora b16a1 for a trade that runs or juss needs a tranny or $600 takes all txt me tha name is derek and tha numba is 8453219273
absoluteg, he isn't trying to sell you anything or buy anything from you. He is just wanting to know what to do to get his D16z6 working in his civic.
^This is not the place for a classifieds ad.
so thats all ill need is the z6 wireing the obd0 to obd1 conversion and the z6 ecu
what do you mean by z6 wiring?
you need the stock harness with ecu jumper and p28 attached. then you run the wires from the jumper into the engine bay for 4 wire o2, vtec, etc. either switch plugs or run a dizzy adapter (which comes with the rywire kit) so that you can plug in your obd1 distributor.
ok so the stock si wiring
it cause i bought the crx with nothing in it no motor or harness or ecu and i didnt want to buy the wrong harness and i already had the z6 but the motor only no harness eather and it come with the crx si manifold alredy .... thanx for the help
Just make sure you get the engine harness for a 88-89 CRX si. The 90-91 won't work either. Does the car still have a cabin harness?
