josh_crewdson@y
i used the obd0 to obd1 harness adapter.
the obd2 injectors are wired correctly to a1, a3, a5, a7 and yellow/black wires go to a15(no resistor box). i have spark from the obd2 dizzy, and no cel's from my p30. i can get it to run with starter fluid, so my assumption is that the injectors aren't firing. i have power from the FI wire at the main relay, and have fuel at the rail. so what might the problem be?
