B16a2 swap into 97 civic coupe
Silo
Whats up everyone, I am swapping a b16a2 I bought into my 97 civic, taking out my d16y7.
I was curious as to a few things. Will I be able to use old parts of my stock motor?
I have hasport motor mounts, shift linkage, a wiring harness from an Integra if that will work? I got the stock 00' SI ecu too.
Can I use my stock motor power steering and will it fit the b16 brackets?
yes you can use your stock motor power steering bracket to fit the b16 they are almosts the same motor..
They are not even close to the same motor, but yes some of the mounts and brackets are interchangeable.
if you can find a 96-98 EX engine to ECU harness, it'll eliminate the need to run extra wires for VTEC, knock, and IACV.
