Ressurecting my CF hood
CorysHBB2
This is my first write up so bear with me ;)
The clearcoat has been peeling and yellowing for awhile so i figured it was time to do something about it
I started sanding with 320 grit on a palm sander to completely strip the clear off
I then used a cheap white spray can primer for a guide coat to make sure i got all the 320 scratches out when i sanded with 400 and again with 600
I then wet sanded with 1000 grit as a final sand before clear.
I did my buddys Evo 8 spoiler at the same time
I wiped it down with wax and grease remover and tack clothed it
I used Keystone Euroclear
I had to bust out the tweezers a couple times cuz the damn bugs kept landing in it in between coats. 5 coats later and :D
My buddys spoiler
Before sanding and buffing
And after
sorry about the quality of the pics all i have is my iphone :shrug2:
DIY link: http://www.clubcivic.com/board/showthread.php?t=63197 http://www.clubcivic.com/board/showthread.php?t=63197http://www.clubcivic.com/board/showthread.php?t=63197
Very easy.. just time consuming haha. Thats my Evo there. The bottom portion of the wing was peeling to the point were the carbon was showing..:eek:. Anyways BOTH look a lot better then before... BTW Good Write Up!! :rimshot:
Wanna do mine? lol...mine looks like shit. I really wish someone i knew could do it lol...Id make them help me lol.
you can do it its really not that hard :cool: the clear is the only tricky part :confused: and if you screw that up you can always sand it down and try again.or theres always the option to take it to a shop after you sand it and have them clear it. it might run you $100 or so. either way the finished product is gona be :D:D:D
Read the tread it says how to fix it.. there also is another thread on fixing a cf hood..
