bryanjenks
i have an em1 with a d16 y8 swap...i just bought a b16a2 block, what all do i need to complete this swap and what if anything from my current setup can i reuse?
All of this and an ECU for a 00 Si, B16 starter, 99-00 B16 rear mount bracket, 99-00 B16 AC bracket and compressor if you want AC, 99-00 Si PS pump and brackets, 99-00 Si dizzy. You can use all the rubber mounts from the D16. You are better off getting a complete B16 swap at this point. You need so much if you only have the long block.The only thing you can use is the stock wiring harness. You will need new mounts, shift linkage, ecu, trans, axles. that should be it
yeah that stuff too but you could switch it to obd1 i dont like obd2 very well
