trouble starting the teg
eg6sir
Supa Mod
VIP
Last night i tried to start the teg and it just cranked over like it was out of gas... i tried pumping the gas and it got it started... any ideas? Need to fix it asap
got to start with the basic check for fuel and spark
my iacv sticks a lil when its cold out and does the same thing, if i give it half throttle and crank it its fine. btw i have a gsr iacv. A buddy wit a gsr has the same issue.
fuel pump / filter??
i have never had to replace a fuel pump and this guy i know has worked on honda for over 30 years has never had to replace a fuel pump.
[QUOTE ]got to start with the basic check for fuel and spark
he says it starts just gotta pump the gas that means its getting spark and fuel.
Ill check out the iacv... could be the fuel filter though, last time I changed it was 4-5 years ago... plus the woman always drives on empty
Come on... u kidding me? Of course there is gas.. like half tank
But went and tried to start this morning and it fired right up
hey, i'm not the one who said she drives it on empty all the time. lol
Try checking your distributor as it can be intermittent result from wear and tear and high temperature may cause it to fail temporary. Delivery of fuel into engine and it could be fuel filter or worse fuel pump.
check to make sure ur fuel pump is priming properly, my turbod b20 vtec eg had a warlbro 255 fuel pump and it had the same problems turn ur key on untill the cel light turns off then turn it over and if you still have to pump it then have it checked
i went out the next day and she fired right up.. been fine since.. she was just being moody that afternoon i guess
well, why are you gas pumping a fuel injected car? lol
