93 starting problems
ruhbrducky
93 Honda Accord, 5 speed man. 280k miles
Ok well there seems to be no apparent patern to this problem but here goes...It will crank but not start. Leave it alone for a couple hrs to a day and it starts like nothing was ever wrong. Does it hot or cold. What we've replaced....main relay, temp sensor, Ignitor and distributor cap. We've checked....fuel pump, spark plugs.
Wondering if its the Ignition Switch?? Any ideas or suggestions??
everytime it does not start is it moist, because if moisture gets in the distributor there is your problem, could be ignition switch, or a bad engine/chassis ground
also welcome to hondaswap
and since you said u checked spark plugs, you probly checked if your getting spark to the plugs, also try to check TDC and see if the timing is correct
Mine doin the same man an I've replaced almost everything that deals with the firing system but for whatever reason still can't get power past my external coilpack
An did u manage to figure out
Oh an shot in the dark but check the capacitors on your ecm
