Get my cel off!
importfancy
ECU throwin a code 12. Engine doesnt have an EGR valve, hence why the ECU is looking for it and throwing the code. How the fuck do I get the Check Engine Light off? Need to do it soon before inspection runs out!
If it is throwing code 12 and you don't have EGR than either the ECU is bad or you have the wrong one for that engine. Either way you would have to get a different one. Unless you can chip it like AHHVTEC suggested.
well.. u could always remove the bulb behind ya check engine light on the cluster and pray to god they don't plug in ya ECU... just my idea
Wouldn't work because it needs to at least light up while the fuel pump primes.
