My Crx Pics
dilbeckskate
infamous
Heres some pics of my CRX, got the traction bars all bolted up now, cant wait for the snow to melt to try them out
ha well will sombody please move it ? i opologise, I just quickly posted the picks after I re-sized them and wasnt paying attention
it's ok. we won't neg rep you for a while. lol hell, i can't even give you the positive rep i owe you because i have to spread it around first. remind me, i'll get back to you.
Did they actually come with a panel covering the fuse box or did they leave that open, cause mine doesn't have it either, and I figured it was just tossed.
hahahahhhaa
Why do you have a one way check valve on that tube? Whats up with the foam padding on the fuel rail?
stock b16?
hahahahhhaa
stock b16?
Ha I had 2 peices of hose and needed to join them together to make it long enough haha figured it couldnt hurt, and idk I was actually experimenting with the foam, thought it made my engine bay look better dull'd down a little, and its a factory b16a with a port and polished head, and a gsr tranny and fuel rail/injectors, nuttin special, its fun though
looking good.
be careful with some of that rust you have on the shock. try to keep them lubed at least.
how do you like the traction bars?
Ahh... vac. line or whatever is like $1/ft and would look a lil better. As far as the foam... :rolleyes: looks completely out of place! I'm all for experimenting though
Nice crx............. Simple and clean.........
looking good.
Ha I lubed them yesterday, the traction bars really just make my suspension feel stiffer, it will still spin the piss outa them, but u dnt feel the car spinning at all, appreciate everything guys
Not sure if it crossed your mind, but if I were you (and if you haven't already) i'd pull the radius rods out, pull the heim joints and apply copius amounts of anti-seize to them. If yours are anything like my Full-Race ones, the joints and rods aren't coated and will seize at the first sign of moisture!
